48-464 resistor question
I often put 1 watt resistors in series or parallel to dissipate larger amounts of power. If you put two 110 ohm resistors in series, each will dissipate half the total power, and the total resistance will be 220 ohms. Two 440 ohm resistors in parallel will accomplish the same result, but 440 ohm isn't a common value.
Philco bias resistors (such as the Candohms) are sometimes odd values that aren't easy to find today, so I often put two or even three smaller value resistors in series to obtain the same resulting resistance as the original. I try to use resistors that are as close as possible to the same value while summing to the desired resistance so that each will dissipate close to the same proportion of the power. I've done this with several radios without problems.
If you can find a 220 ohm wire-wound resistor in two watts or greater, you are probably better off, since their inductance should theoretically help with filtering.
John Honeycutt
48-464 resistor question - by Jim Dutridge - 12-31-2010, 01:06 PM
Re: 48-464 resistor question - by exray - 12-31-2010, 07:12 PM
Re: 48-464 resistor question - by Ron Ramirez - 12-31-2010, 08:39 PM
Re: 48-464 resistor question - by Jim Dutridge - 01-01-2011, 09:53 PM
Re: 48-464 resistor question - by Raleigh - 01-03-2011, 04:09 PM
Philco 89 indicator light.
There are currently 4139 online users. [Complete List]
» 3 Member(s) | 4136 Guest(s)
