EH Scott Philharmonic AM/FM
Threads: 112
City: Medford OR (OR what?)
The last one that I used was Advanced Plating - not an endorsement but they did a good job on the last chassis in reasonable time and at reasonable(?) cost. They are in Nashville. 800-588-6686.
Radios don't seem to be a problem for them, but, if you know that you have a zinc or aluminum part it is better to work that out in advance rather than trusting that they will take special precautions on their own. One plater did the cans just fine but burned off the little 1/4' studs that hold them on (brass).
RE: EH Scott Philharmonic AM/FM - by Phlogiston - 10-25-2019, 08:00 PM
Users browsing this thread: 13 Guest(s)
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM |
There are currently 7712 online users. [Complete List] » 2 Member(s) | 7710 Guest(s)
