Latest on the 37-650
I'm definitely not an expert on this, but I was under the impression that you shouldn't change from solid to stranded wire in the RF section of the circuit. RF signals travel along the outside surface of the wire, therefore changing to stranded wire could affect the RF characteristics.
Derek
Latest on the 37-650 - by Robbie Roberts - 02-21-2006, 10:57 PM
[No subject] - by Bill Hutchinson - 02-22-2006, 06:39 PM
[No subject] - by Robbie Roberts - 02-22-2006, 06:41 PM
[No subject] - by Bill Hutchinson - 02-22-2006, 06:50 PM
[No subject] - by Chuck Schwark - 02-22-2006, 07:35 PM
[No subject] - by Robbie Roberts - 02-22-2006, 07:38 PM
[No subject] - by Chuck Schwark - 02-22-2006, 08:29 PM
[No subject] - by Robbie Roberts - 02-22-2006, 08:35 PM
[No subject] - by Steve Chambers - 02-22-2006, 08:44 PM
[No subject] - by Robbie Roberts - 02-22-2006, 08:47 PM
[No subject] - by Chuck Schwark - 02-22-2006, 09:00 PM
[No subject] - by Robbie Roberts - 02-23-2006, 12:56 AM
[No subject] - by Derek D - 02-23-2006, 01:33 AM
[No subject] - by Robbie Roberts - 02-23-2006, 01:40 PM
Philco 91 Tuning Condenser
There are currently 9431 online users. [Complete List]
» 3 Member(s) | 9428 Guest(s)
