Help with Philco HR-1 Beam of Light Record Cutter
I am restoring a Philco Beam of Light phonograph with an HR-1 record cutter/recorder. It's the Model 41-608 radio/phono.
Aside from working to get the changer to work correctly, I need to know the following:
1. Where do you connect a microphone? Nothing I can find specifically shows me where to connect it. It think it connects to the extra terminal on the black external transformer (see photo).
2. What type of record blanks should I use to make recordings? Are PVC or polycarbonate okay? Also, I learned that the old blanks had a hole that engaged with the tab on the platter to keep the blank from slipping as it was being cut. I guess I could drill a hole in each blank to get such a hole. I don't want to buy NOS blanks if possible.
Gib at WestTech has rebuilt the pickup and cutter cartridges, so they should work.
Can anyone who has experience with this unit help me with the microphone hookup and a source for record blanks that will work with this cutter?
Thanks!
There are currently 9509 online users. [Complete List]
» 1 Member(s) | 9508 Guest(s)
