16B Shoulder Tombstone Code 125 dial string
I found a roll of what seemed to be that same item at Walmart, but it was an 18 thickness and seemed too thin. I think they changed suppliers. The crochet line I bought looked exactly like that one, but was called Red Heart.
I then tried nylon Mason's line, size 36 and coated it with rubber cement. It worked. I'll save and use each line depending on the size of the radio I am working on in the future.
Thanks a lot for your help. This radio plays very well!
Re: 16B Shoulder Tombstone Code 125 dial string - by SteveJB - 01-05-2011, 03:44 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6681 online users. [Complete List]
» 2 Member(s) | 6679 Guest(s)
