A 70 cabinet with a 20 chassis and dual 71A's?
Well,
It is a large hole... The guy I bought it from put the knobs on. I'll throw on some 20 knobs.. Icon_smile
Kirk Icon_smile
Philco 91 Tuning Condenser
