A 70 cabinet with a 20 chassis and dual 71A's?
It's a shame the grill cloth has that one hole in it. It is in great shape otherwise and seems original.
It almost merits trying to patch it rather than replace altogether.
A patch cut from some unusable piece of original cloth which could be found would do the job.
Philco 91 Tuning Condenser
There are currently 10204 online users. [Complete List]
» 2 Member(s) | 10202 Guest(s)
