c- c+ on old battery radios
Fortunately C battery voltages are not high, so I just make my own using modern batteries. I solder the terminals together. Some liquid flux made from powdered violin rosin and rubbing alcohol helps with this. Make a suitable box from white cardboard, and there you are. The drain is so low that a series of C cells hooked up will last for years. You can also tap them off to get -3, -4.5, .-6, -9 volts, or whatever you need.
c- c+ on old battery radios - by corey12 - 11-06-2019, 10:00 PM
RE: c- c+ on old battery radios - by mikethedruid - 11-07-2019, 12:46 PM
RE: c- c+ on old battery radios - by Chas - 11-07-2019, 03:40 PM
RE: c- c+ on old battery radios - by corey12 - 11-07-2019, 04:10 PM
RE: c- c+ on old battery radios - by Chas - 11-07-2019, 06:59 PM
RE: c- c+ on old battery radios - by corey12 - 11-07-2019, 08:36 PM
RE: c- c+ on old battery radios - by Chas - 11-07-2019, 09:38 PM
RE: c- c+ on old battery radios - by corey12 - 11-08-2019, 09:23 PM
Gloritone 27 Radio
Another make I have seen from U.S Radio and Television was Apex Electric, or U.S Apex, the badge on some of those had a ...Arran — 12:56 AM
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
There are currently 2464 online users. [Complete List]
» 1 Member(s) | 2463 Guest(s)
