There are two ways to approach this. First is to measure each section of the candohm in question to find the bad section or sections. Solder a resistor of the same resistance and sufficient wattage across each of the the bad sections. The other is to remove the old candohm entirely and put a long terminal strip in the same location, then put suitable resistors across sections of the terminal strip, connect the wires where they go, and solder everything in place. The latter is often preferable when dealing with a canohm where one section is bad, since another section may go bad soon. The first method works OK when all sections of the candohm are bad and you can use the old candohm itself as the terminal strip. I have used both methods.
46-350 - by crazycars - 11-08-2019, 09:12 AM
RE: 46-350 - by mikethedruid - 11-08-2019, 01:37 PM
RE: 46-350 - by crazycars - 11-08-2019, 06:41 PM
RE: 46-350 - by W8ZV - 11-09-2019, 01:19 PM
RE: 46-350 - by crazycars - 11-09-2019, 02:09 PM
RE: 46-350 component - by crazycars - 11-11-2019, 12:45 AM
RE: 46-350 - by KCMike - 11-11-2019, 12:22 PM
RE: 46-350 - by crazycars - 11-11-2019, 02:12 PM
RE: 46-350 - by ChrisRag - 11-12-2019, 09:41 AM
There are currently 4518 online users. [Complete List]
» 1 Member(s) | 4517 Guest(s)
