Philco 112 Highboy
"Be careful with volume pot. Don't wipe insides with alcohol." Oh how I miss carbon tetrachloride ! It was what we used to use to clean pots. D**n eco freaks killed that. What little we used could not have been much of a cause of the "hole in the ozone."
Philco 112 Highboy - by benchrest - 11-09-2019, 07:59 PM
RE: Philco 112 Highboy - by KCMike - 11-09-2019, 10:36 PM
RE: Philco 112 Highboy - by morzh - 11-09-2019, 10:52 PM
RE: Philco 112 Highboy - by mikethedruid - 11-09-2019, 11:29 PM
RE: Philco 112 Highboy - by rfeenstra - 11-10-2019, 12:53 AM
RE: Philco 112 Highboy - by klondike98 - 11-10-2019, 11:27 AM
RE: Philco 112 Highboy - by benchrest - 11-10-2019, 11:51 AM
RE: Philco 112 Highboy - by Nathan Slingerland - 11-10-2019, 02:06 PM
There are currently 9749 online users. [Complete List]
» 1 Member(s) | 9748 Guest(s)
