Philco 112 Highboy
Thanks for the post. Didn't realize there was a missing tube shield. But I found a picture on another forum showing what the shield looks like from the back. I can see the shield covers the back and top but no view of other angles. I assume it cover the sides but is open on the front or the tubes would over heat if fully enclosed. Will keep an eye open on ebay.
Rich
Philco 112 Highboy - by benchrest - 11-09-2019, 07:59 PM
RE: Philco 112 Highboy - by KCMike - 11-09-2019, 10:36 PM
RE: Philco 112 Highboy - by morzh - 11-09-2019, 10:52 PM
RE: Philco 112 Highboy - by mikethedruid - 11-09-2019, 11:29 PM
RE: Philco 112 Highboy - by rfeenstra - 11-10-2019, 12:53 AM
RE: Philco 112 Highboy - by klondike98 - 11-10-2019, 11:27 AM
RE: Philco 112 Highboy - by benchrest - 11-10-2019, 11:51 AM
RE: Philco 112 Highboy - by Nathan Slingerland - 11-10-2019, 02:06 PM
There are currently 9727 online users. [Complete List]
» 1 Member(s) | 9726 Guest(s)
