Loose wire...
Open winding on the antenna coil.
Measure the resistance from ground the the antenna post with the set unplugged and volume all the way up. Should show a low resistance like a few ohms. If it higher than that the small winding on the ant coil is open. Remove coil and rewind(easy). About 25t of 36G will work fine
Good luck
Loose wire... - by Kico - 01-03-2011, 09:50 AM
Re: Loose wire... - by 7estatdef - 01-03-2011, 10:08 AM
Re: Loose wire... - by Kico - 01-03-2011, 10:24 AM
Re: Loose wire... - by 7estatdef - 01-03-2011, 12:14 PM
Re: Loose wire... - by Kico - 01-03-2011, 12:33 PM
Re: Loose wire... - by 7estatdef - 01-03-2011, 03:01 PM
Re: Loose wire... - by Kico - 01-05-2011, 05:47 PM
Re: Loose wire... - by 7estatdef - 01-05-2011, 06:16 PM
Re: Loose wire... - by gary rabbitt - 01-05-2011, 11:18 PM
Re: Loose wire... - by gary rabbitt - 01-06-2011, 01:02 AM
Re: Loose wire... - by Kico - 01-06-2011, 03:19 PM
Re: Loose wire... - by 7estatdef - 01-06-2011, 07:34 PM
Re: Loose wire... - by Kico - 01-06-2011, 08:51 PM
Re: Loose wire... - by 7estatdef - 01-06-2011, 09:33 PM
Re: Loose wire... - by Kico - 01-06-2011, 09:47 PM
Re: Loose wire... - by 7estatdef - 01-06-2011, 10:32 PM
Re: Loose wire... - by Kico - 01-07-2011, 04:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 7694 online users. [Complete List]
» 1 Member(s) | 7693 Guest(s)
