Signal generator SG24/TRM3
Quote:But with oil in them  how do I proceed. Hope its not PCB oil???
Yes, I can say with almost 100% certainty.
If the cap was date coded after 1976 it would not have PCB, but a type of mineral oil.
Pull it out, dispose properly and replace with a mylar type(ish) and a tie strip.
Chas
Pliny the younger
Signal generator SG24/TRM3 - by vecher - 11-14-2019, 10:03 PM
RE: Signal generator SG24/TRM3 - by Chas - 11-15-2019, 08:05 AM
RE: Signal generator SG24/TRM3 - by Jake Blake - 11-15-2019, 08:39 AM
RE: Signal generator SG24/TRM3 - by Chas - 11-15-2019, 10:03 AM
RE: Signal generator SG24/TRM3 - by vecher - 11-17-2019, 11:10 PM
RE: Signal generator SG24/TRM3 - by Jake Blake - 11-18-2019, 06:05 AM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 7548 online users. [Complete List]
» 2 Member(s) | 7546 Guest(s)
