What model is this?
Thanks!
Here's the back.
https://postimg.cc/MMp1Zkf7
What model is this? - by RunRUp - 11-15-2019, 07:15 AM
RE: What model is this? - by Ron Ramirez - 11-15-2019, 09:19 AM
RE: What model is this? - by OldRestorer - 11-15-2019, 10:19 AM
RE: What model is this? - by klondike98 - 11-15-2019, 01:51 PM
RE: What model is this? - by OldRestorer - 11-15-2019, 02:40 PM
RE: What model is this? - by RunRUp - 11-15-2019, 04:56 PM
RE: What model is this? - by Ron Ramirez - 11-15-2019, 04:59 PM
RE: What model is this? - by RunRUp - 11-20-2019, 09:57 AM
RE: What model is this? - by OldRestorer - 11-20-2019, 10:09 AM
RE: What model is this? - by Radioroslyn - 11-20-2019, 10:39 AM
RE: What model is this? - by RunRUp - 11-20-2019, 10:39 AM
RE: What model is this? - by Radioroslyn - 11-20-2019, 01:30 PM
Philco 91 Tuning Condenser
There are currently 10178 online users. [Complete List]
» 2 Member(s) | 10176 Guest(s)
