What model is this?
Congratulations you've got a 650B!
https://philcoradio.com/gallery2/1936a/#Model_650B
Here's the services info: http://www.nostalgiaair.org/pagesbymodel...013824.pdf
A cleaner schematic can be found here: https://philcoradio.com/library/download...l.%201.pdf
Was built in the Spring of 1935 till Spring of 1936 for the 1936 model year.
ps If you are wondering about the bandswitch knob it is a Philco and sporadically used in 1936 only.
What model is this? - by RunRUp - 11-15-2019, 07:15 AM
RE: What model is this? - by Ron Ramirez - 11-15-2019, 09:19 AM
RE: What model is this? - by OldRestorer - 11-15-2019, 10:19 AM
RE: What model is this? - by klondike98 - 11-15-2019, 01:51 PM
RE: What model is this? - by OldRestorer - 11-15-2019, 02:40 PM
RE: What model is this? - by RunRUp - 11-15-2019, 04:56 PM
RE: What model is this? - by Ron Ramirez - 11-15-2019, 04:59 PM
RE: What model is this? - by RunRUp - 11-20-2019, 09:57 AM
RE: What model is this? - by OldRestorer - 11-20-2019, 10:09 AM
RE: What model is this? - by Radioroslyn - 11-20-2019, 10:39 AM
RE: What model is this? - by RunRUp - 11-20-2019, 10:39 AM
RE: What model is this? - by Radioroslyn - 11-20-2019, 01:30 PM
There are currently 10250 online users. [Complete List]
» 2 Member(s) | 10248 Guest(s)
