First Restoration -- Already Stumped :o)
Welcome to the Phorum!
Icon_wave
My guess...I suspect someone in the factory made an error and slapped the wrong label on the cabinet and they were not going to waste a cabinet nor try to scrape it off so down the line it went with the wrong label on it. Icon_confused
RE: First Restoration -- Already Stumped :o) - by klondike98 - 11-20-2019, 04:21 PM
There are currently 5786 online users. [Complete List]
» 2 Member(s) | 5784 Guest(s)
