another one in my area for $150.  Worth picking up?
46-1209 - by rfeenstra - 11-22-2019, 12:13 AM
RE: 46-1209 - by Ron Ramirez - 11-22-2019, 07:23 AM
RE: 46-1209 - by rfeenstra - 11-22-2019, 10:08 AM
RE: 46-1209 - by OldRestorer - 11-22-2019, 10:27 AM
RE: 46-1209 - by rfeenstra - 11-22-2019, 08:18 PM
Philco 91 Tuning Condenser
