Fairbanks Morse model 56
My Digital Volt Meter doesnt have the meg range to read some resistors is what i meant to say.. Icon_smile
The hard part for me will be translating the resistor list from the riders schematic into modern values. (im a bit rusty)
Thanks for the offer to search for a tube for me, but i agree rest your knee..  I forgot all about findatube, i think i used them to replace all the tubes in a 39 wards i did a few years back.. I may try them again.. Thanks... Icon_thumbup
Fairbanks Morse model 56 - by Stall-U-Rated - 11-19-2019, 01:51 AM
RE: Fairbanks Morse model 56 - by Radioroslyn - 11-19-2019, 10:30 AM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 11-19-2019, 06:38 PM
RE: Fairbanks Morse model 56 - by Radioroslyn - 11-19-2019, 09:15 PM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 11-21-2019, 01:46 AM
RE: Fairbanks Morse model 56 - by Eliot Ness - 11-21-2019, 02:27 AM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 11-21-2019, 11:48 PM
RE: Fairbanks Morse model 56 - by Eliot Ness - 11-22-2019, 01:06 AM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 11-22-2019, 02:15 AM
RE: Fairbanks Morse model 56 - by Steve Davis - 11-22-2019, 07:46 AM
RE: Fairbanks Morse model 56 - by Eliot Ness - 11-22-2019, 11:31 AM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 11-24-2019, 01:54 AM
RE: Fairbanks Morse model 56 - by Steve Davis - 11-24-2019, 12:31 PM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 12-05-2019, 10:00 PM
RE: Fairbanks Morse model 56 - by mikethedruid - 02-23-2020, 01:23 AM
RE: Fairbanks Morse model 56 - by Radioroslyn - 02-23-2020, 01:59 AM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 02-23-2020, 02:06 AM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 02-27-2020, 12:01 AM
Philco 91 Tuning Condenser
There are currently 10073 online users. [Complete List]
» 1 Member(s) | 10072 Guest(s)
