Zenith 6-S-1-whatever
#52
This morning, I resumed work on the Zenith with the 2nd IF transformer.
Here's a shot of the one Greg sent me next to the set's original IF transformer.
The replacement looks just like the 2nd IF from the 6-S-254. It, like the 6-S-254 2nd IF, does not have the spring shield over the grid wire. Yet the part numbers for both of these IFs are exactly the same.
When I added new wires to the replacement 2nd IF and put it back into its (freshly polished) can, I also installed the spring grid wire shield. I assumed there was a reason it had the wire shield originally.
Here's a look after it was installed:
A final under-chassis view, or, Take 2 if you will:
Yes, I used new plastic covered wire to replace the original IF can wires. Why? Two reasons: (1) the AES cloth covered wire is really too thick for this job; and (2) the original wires were solid, and so are these.
Now for a speaker, with a good audio output transformer, to try this Zenith out.
I quickly found the answer in a Philco 89B cathedral I had bought at Radiorama in Cincinnati back in June.
The K-7 speaker's field coil measured 1096 ohms. The output transformer primary was good as well!
I put together a new speaker cable, using the base of a long-dead 5-pin tube as the speaker connector. I removed pin 3 from the old tube base, installed four cloth-covered wires, twisted the four wires together into a cable, and soon had it all together.
more...
Zenith 6-S-1-whatever - by Ron Ramirez - 11-03-2019, 02:04 PM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-03-2019, 02:08 PM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-03-2019, 02:12 PM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-03-2019, 02:21 PM
RE: Zenith 6-S-1-whatever - by PhilcoJohn - 11-03-2019, 07:20 PM
RE: Zenith 6-S-1-whatever - by NostalgiaRadioTime - 11-03-2019, 07:39 PM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-03-2019, 07:46 PM
RE: Zenith 6-S-1-whatever - by NostalgiaRadioTime - 11-03-2019, 07:49 PM
RE: Zenith 6-S-1-whatever - by KCMike - 11-03-2019, 10:11 PM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-03-2019, 10:12 PM
RE: Zenith 6-S-1-whatever - by morzh - 11-04-2019, 12:14 AM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-05-2019, 10:43 PM
RE: Zenith 6-S-1-whatever - by rfeenstra - 11-05-2019, 10:49 PM
RE: Zenith 6-S-1-whatever - by GarySP - 11-05-2019, 11:03 PM
RE: Zenith 6-S-1-whatever - by mikethedruid - 11-05-2019, 11:30 PM
RE: Zenith 6-S-1-whatever - by morzh - 11-06-2019, 10:17 AM
RE: Zenith 6-S-1-whatever - by WyTex - 11-08-2019, 06:52 AM
RE: Zenith 6-S-1-whatever - by OldRestorer - 11-10-2019, 08:35 AM
RE: Zenith 6-S-1-whatever - by radiohenry - 11-11-2019, 12:45 PM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-13-2019, 07:56 PM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-13-2019, 08:04 PM
RE: Zenith 6-S-1-whatever - by KCMike - 11-13-2019, 08:25 PM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-13-2019, 09:39 PM
RE: Zenith 6-S-1-whatever - by Eliot Ness - 11-14-2019, 10:10 AM
RE: Zenith 6-S-1-whatever - by morzh - 11-14-2019, 10:37 AM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-14-2019, 01:29 PM
RE: Zenith 6-S-1-whatever - by morzh - 11-14-2019, 05:03 PM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-14-2019, 08:27 PM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-14-2019, 08:38 PM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-15-2019, 11:51 PM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-15-2019, 11:59 PM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-16-2019, 12:04 AM
RE: Zenith 6-S-1-whatever - by Nathan Slingerland - 11-16-2019, 12:46 AM
RE: Zenith 6-S-1-whatever - by PhilcoJohn - 11-16-2019, 08:26 AM
RE: Zenith 6-S-1-whatever - by 462ron - 11-16-2019, 09:54 AM
RE: Zenith 6-S-1-whatever - by Eliot Ness - 11-16-2019, 10:01 AM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-16-2019, 10:53 PM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-16-2019, 11:12 PM
RE: Zenith 6-S-1-whatever - by klondike98 - 11-17-2019, 09:28 AM
RE: Zenith 6-S-1-whatever - by Ed Locker - 11-17-2019, 10:36 AM
RE: Zenith 6-S-1-whatever - by Eliot Ness - 11-17-2019, 10:50 AM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-17-2019, 11:53 AM
RE: Zenith 6-S-1-whatever - by KCMike - 11-17-2019, 12:46 PM
RE: Zenith 6-S-1-whatever - by NostalgiaRadioTime - 11-17-2019, 07:57 PM
RE: Zenith 6-S-1-whatever - by NostalgiaRadioTime - 11-17-2019, 08:22 PM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-17-2019, 08:26 PM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-17-2019, 08:36 PM
RE: Zenith 6-S-1-whatever - by Jake Blake - 11-17-2019, 08:51 PM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-22-2019, 10:46 PM
RE: Zenith 6-S-1-whatever - by NostalgiaRadioTime - 11-23-2019, 02:29 AM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-23-2019, 08:51 AM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-23-2019, 05:07 PM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-23-2019, 05:24 PM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-23-2019, 05:33 PM
RE: Zenith 6-S-1-whatever - by Ed Locker - 11-23-2019, 08:01 PM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-23-2019, 11:04 PM
RE: Zenith 6-S-1-whatever - by NostalgiaRadioTime - 11-24-2019, 01:50 AM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-24-2019, 08:51 AM
RE: Zenith 6-S-1-whatever - by NostalgiaRadioTime - 11-24-2019, 02:49 PM
RE: Zenith 6-S-1-whatever - by NostalgiaRadioTime - 11-24-2019, 03:37 PM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-24-2019, 10:23 PM
RE: Zenith 6-S-1-whatever - by rfeenstra - 11-24-2019, 10:46 PM
RE: Zenith 6-S-1-whatever - by NostalgiaRadioTime - 11-24-2019, 11:53 PM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-25-2019, 10:15 PM
RE: Zenith 6-S-1-whatever - by KCMike - 11-25-2019, 11:17 PM
RE: Zenith 6-S-1-whatever - by NostalgiaRadioTime - 11-26-2019, 12:44 AM
RE: Zenith 6-S-1-whatever - by Eliot Ness - 11-26-2019, 10:13 AM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-26-2019, 10:18 PM
RE: Zenith 6-S-1-whatever - by NostalgiaRadioTime - 11-26-2019, 11:38 PM
RE: Zenith 6-S-1-whatever - by Steve Davis - 11-26-2019, 11:56 PM
RE: Zenith 6-S-1-whatever - by klondike98 - 11-27-2019, 10:54 AM
RE: Zenith 6-S-1-whatever - by Ron Ramirez - 11-27-2019, 10:08 PM
Hi Howard, if memory serves, and many times it doesn’t, I vaguely remember working on a Philco that had that pin you hav...462ron — 09:00 AM
Gloritone 27 Radio
Hello John, Thanks for the information and Arran I have heard of Wells Gardner and I have heard of Apex but I did not ...radiorich — 08:17 AM
Gloritone 27 Radio
Another make I have seen from U.S Radio and Television was Apex Electric, or U.S Apex, the badge on some of those had a ...Arran — 12:56 AM
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
