Jackson Bell model 68 Tulip
No, Bill, it has three RF amplifier stages. The fourth "stage" is the detector circuit.
Jackson Bell model 68 Tulip - by Bill Cahill - 01-11-2011, 10:01 AM
Re: Jackson Bell model 68 Tulip - by rghines1 - 01-11-2011, 10:47 AM
Re: Jackson Bell model 68 Tulip - by Bill Cahill - 01-11-2011, 01:12 PM
Re: Jackson Bell model 68 Tulip - by Ron Ramirez - 01-11-2011, 02:33 PM
Re: Jackson Bell model 68 Tulip - by Bill Cahill - 01-11-2011, 03:55 PM
Re: Jackson Bell model 68 Tulip - by Ron Ramirez - 01-11-2011, 04:08 PM
Re: Jackson Bell model 68 Tulip - by Bill Cahill - 01-11-2011, 11:11 PM
Philco 91 Tuning Condenser
