Fairbanks Morse model 56
My tubes arrived today and the used 6A7 i got performs well in the radio without that whistle. Its a philco like the one that was in there that i nipped off the tip.. The tube that was disagreeing was an RCA brand, who knows what the difference was...
So ill send it through an alignment and see how it goes..
Fairbanks Morse model 56 - by Stall-U-Rated - 11-19-2019, 01:51 AM
RE: Fairbanks Morse model 56 - by Radioroslyn - 11-19-2019, 10:30 AM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 11-19-2019, 06:38 PM
RE: Fairbanks Morse model 56 - by Radioroslyn - 11-19-2019, 09:15 PM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 11-21-2019, 01:46 AM
RE: Fairbanks Morse model 56 - by Eliot Ness - 11-21-2019, 02:27 AM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 11-21-2019, 11:48 PM
RE: Fairbanks Morse model 56 - by Eliot Ness - 11-22-2019, 01:06 AM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 11-22-2019, 02:15 AM
RE: Fairbanks Morse model 56 - by Steve Davis - 11-22-2019, 07:46 AM
RE: Fairbanks Morse model 56 - by Eliot Ness - 11-22-2019, 11:31 AM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 11-24-2019, 01:54 AM
RE: Fairbanks Morse model 56 - by Steve Davis - 11-24-2019, 12:31 PM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 12-05-2019, 10:00 PM
RE: Fairbanks Morse model 56 - by mikethedruid - 02-23-2020, 01:23 AM
RE: Fairbanks Morse model 56 - by Radioroslyn - 02-23-2020, 01:59 AM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 02-23-2020, 02:06 AM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 02-27-2020, 12:01 AM
Philco 91 Tuning Condenser
There are currently 10092 online users. [Complete List]
» 3 Member(s) | 10089 Guest(s)
