Dial Light Bulb for Model 60MB
From the Philco Service Bulletin for the Model 60, the pilot lamp is p/n 6608, which is a screw base, 6-8 volt lamp. Equivalent to a #46 lamp.
Info from the PARTS section of my site.
Dial Light Bulb for Model 60MB - by Guest - 02-27-2006, 07:03 PM
[No subject] - by Chuck Schwark - 02-27-2006, 07:21 PM
[No subject] - by Guest - 02-27-2006, 08:36 PM
There are currently 9807 online users. [Complete List]
» 1 Member(s) | 9806 Guest(s)
