Z 5-S-127 Chassis Done - Almost
I more or less finished one of two 5-S-127 chassis, recapped, reresisotored (if that's a word)... It works on all bands pretty well but still needs to be aligned, voltages need better checking and the dial needs replacing.
But I think it's getting displaced from the "workbench" by the 37-116 I got last week. So that's it for now.
I tried some things I'd like to apply to the 37-116. I think these things helped the appearance...
- Electrolytics restuffed and negative terminals soldered to insides of  the original aluminum cans.
- Paper caps restuffed, ends capped off with beeswax and lightly coated with wax. Anybody think it's a bad idea to use beeswax? They aren't full of it, just the very end. I stuck cardboard disks into the ends before waxing. I'd like something that melted at a bit higher temp. Carnauba seems shrink and crack as it cools. I tried mix but not much better.
- Resistors replaced with new ones all encapsulated with resin to appear to be dog bones. They seem to have originally used both dog bone and non but with no rhyme or reason to which where. Probably just availability.
Before (Photos don't do justice to filth on it.):
After:
Greg O.
Whitehall, PA
Z 5-S-127 Chassis Done - Almost - by Greg - 12-08-2019, 03:29 PM
RE: Z 5-S-127 Chassis Done - Almost - by Greg - 12-12-2019, 10:57 PM
Gloritone 27 Radio
Another make I have seen from U.S Radio and Television was Apex Electric, or U.S Apex, the badge on some of those had a ...Arran — 12:56 AM
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
There are currently 2465 online users. [Complete List]
» 1 Member(s) | 2464 Guest(s)
