Good and low priced multi meter?
". . . but if I was looking for a decent lower cost meter, . . ."
Yes!  I run into an over voltage-thing with my 500 volt Sperry.  At the time, I wasn't thinking about antique radio power supplies.  If I had it to do all over again, I would have taken this Klein also.
Good and low priced multi meter? - by jake wells - 12-05-2019, 08:09 AM
RE: Good and low priced multi meter? - by Jake Blake - 12-10-2019, 11:52 AM
RE: Good and low priced multi meter? - by gregb - 12-10-2019, 07:05 PM
