Just picked up a 1936 Philco 116B Tombstone Radio Today and need some info on it
>I don't know what's going on
Really should rebuild the 7 electrolytic caps before you turn the set on.
>is there a way to test those older tubes without a tube tester?
You can test the heater but that's abt it. That doesn't tell you much abt the performance of the tube just whether it's dead or not.
Something to have a look at is check the resistance across the spkr plug. Use any two pins but measure all of them. If you see a measurement above 5K or so investigate the primary winding of the output transformer. Not a bad idea to do likewise driver transformer (the one over by the single 42 tube). Primary has two connections and the 2ndy has three. Measure the two windings separately.
RE: Just picked up a 1936 Philco 116B Tombstone Radio Today and need some info on it - by Radioroslyn - 12-10-2019, 03:12 PM
Users browsing this thread: 29 Guest(s)
Philco 49-1040
