veneer hole repair
I will sometimes (seldom) tint wood putty, but you will be better off starting with a "walnut", mahogany" or cherry" colored putty which is available at the hardware store.
A small brush can be used with some VD Brown toner - or just brown lacquer - to add a little grain to help blend. This should work for a SMALL hole.
veneer hole repair - by fenbach - 12-10-2019, 03:08 PM
RE: veneer hole repair - by Phlogiston - 12-10-2019, 05:06 PM
RE: veneer hole repair - by John Bartley - 12-10-2019, 05:28 PM
RE: veneer hole repair - by Radioroslyn - 12-10-2019, 06:40 PM
RE: veneer hole repair - by fenbach - 12-10-2019, 07:45 PM
RE: veneer hole repair - by fenbach - 12-11-2019, 10:44 PM
RE: veneer hole repair - by Paul Philco322 - 12-12-2019, 09:12 AM
RE: veneer hole repair - by Jake Blake - 12-12-2019, 11:40 AM
RE: veneer hole repair - by Phlogiston - 12-14-2019, 11:39 PM
