Ron's RCA 9T/10K
Tonight's (Friday) progress:
I finished hooking up C73 and C75, and also connected C74 (0.47 uF) across the positive terminals of C73 and C75.
The underside of the chassis now looks like this:
I realized that I needed to remove and restuff the metal can which contains C64, C65, C66, R23, R24, and R26.
The components are encased in tar. Naturally. I'll have to figure out how I can melt the tar out, with the weather forecast to be rainy this weekend with snow starting Sunday night.
So in the meantime, I set the main chassis aside after cleaning all of the switches and controls, and pulled out the Magic Brain.
How the top of the "Brain" looks with the cover removed:
Very dusty.
Now, the underside of the Magic Brain:
Rubber-covered wires, a couple paper caps, and LOTS of mica caps. Looks like it will be fun to restore. Not.
I decided that I should remove the 0-95 dial scale because it looked as if it could be easily broken.
It was held in place by two set screws.
One of the two set screws promptly broke as soon as I tried to loosen it.
Icon_mad Icon_evil
The other one loosened just fine.
I had to drill out the broken one, and then carefully get the hub loose so I could remove that dial scale.
I probably should remove the multiple band dial scale as well...as soon as I figure out how to remove it, that is.
Ron's RCA 9T/10K - by Ron Ramirez - 12-10-2019, 10:03 PM
RE: Ron's RCA 9T/10K - by mikethedruid - 12-10-2019, 10:16 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-10-2019, 10:18 PM
RE: Ron's RCA 9T/10K - by Nathan Slingerland - 12-11-2019, 12:12 AM
RE: Ron's RCA 9T/10K - by mikethedruid - 12-11-2019, 02:35 AM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-11-2019, 07:16 AM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-11-2019, 07:18 AM
RE: Ron's RCA 9T/10K - by Eliot Ness - 12-11-2019, 10:30 AM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-13-2019, 10:05 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-13-2019, 10:19 PM
RE: Ron's RCA 9T/10K - by Steve Davis - 12-13-2019, 10:39 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-14-2019, 11:47 PM
RE: Ron's RCA 9T/10K - by jake wells - 12-15-2019, 05:59 AM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-15-2019, 10:39 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-15-2019, 10:47 PM
RE: Ron's RCA 9T/10K - by jake wells - 12-15-2019, 10:53 PM
RE: Ron's RCA 9T/10K - by Phlogiston - 12-16-2019, 01:44 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-16-2019, 07:48 PM
RE: Ron's RCA 9T/10K - by Phlogiston - 12-16-2019, 07:59 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-16-2019, 11:32 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-19-2019, 11:06 PM
RE: Ron's RCA 9T/10K - by rfeenstra - 12-19-2019, 11:51 PM
RE: Ron's RCA 9T/10K - by EdHolland - 12-20-2019, 01:30 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-20-2019, 11:38 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-21-2019, 02:03 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-21-2019, 11:26 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-21-2019, 11:28 PM
RE: Ron's RCA 9T/10K - by KCMike - 12-22-2019, 05:58 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-22-2019, 07:32 PM
RE: Ron's RCA 9T/10K - by EdHolland - 12-23-2019, 06:14 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-23-2019, 10:34 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-23-2019, 10:40 PM
RE: Ron's RCA 9T/10K - by Nathan Slingerland - 12-23-2019, 10:41 PM
RE: Ron's RCA 9T/10K - by Steve Davis - 12-23-2019, 11:24 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-24-2019, 08:29 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-25-2019, 10:22 PM
RE: Ron's RCA 9T/10K - by Paul Philco322 - 12-25-2019, 10:44 PM
RE: Ron's RCA 9T/10K - by 462ron - 12-26-2019, 11:49 AM
RE: Ron's RCA 9T/10K - by EdHolland - 12-26-2019, 01:11 PM
Thank you Richard.R3Sons — 01:37 AM
R3Sons, I buy my resistors from either digi key or mouser ! Sincerely Richardradiorich — 01:28 AM
Replicating (dogbone) resistors what method have you used ?
Hello Guys, Ican't wait to try printing some of these I might go ahead and order some from PCB way ! Sincerely Richa...radiorich — 01:26 AM
Does anybody have a line on replacement resistors?R3Sons — 12:21 AM
42-345 Resistors
I replaced all the electrolytic capacitors. That big Philco 12uf 400V electrolytic Vienna sausage. is one I removed and ...proftrussell — 11:58 PM
Well...taht's a start.morzh — 10:15 PM
X6 is out. Only pulling 3mA now, 220mA with the light on. Test point 18 is 12.2 Test point 19 is 12.06R3Sons — 09:46 PM
Philco 7053
Any of you guys have and used this tester?Martinj — 09:27 PM
I would test all, but the X6 is the main suspect. The output is the autotransformer, and it also could potentially ha...morzh — 09:13 PM
Yes, I tested them out of the circuits. I posted my measurements where the first letter was red and the second was blac...R3Sons — 08:52 PM
