Grilling Your Radio
Interesting!!
Grilling Your Radio - by Phlogiston - 12-14-2019, 05:49 PM
RE: Grilling Your Radio - by rfeenstra - 12-14-2019, 07:55 PM
RE: Grilling Your Radio - by Jake Blake - 12-14-2019, 09:37 PM
RE: Grilling Your Radio - by Phlogiston - 12-15-2019, 03:52 PM
RE: Grilling Your Radio - by EdHolland - 12-20-2019, 05:18 PM
RE: Grilling Your Radio - by Phlogiston - 12-20-2019, 05:50 PM
Indeed. Thank you all. I'll remove and test the rest of the transistors. I'm trying to trace everything at the test p...R3Sons — 12:06 PM
Yes, if the speaker was disconnected or bad connections, it could cause high enough voltage spikes on the collector to k...462ron — 10:40 AM
42-345 Resistors
Good.morzh — 10:38 AM
I would check things around before simply replacing the transistor. Something killef it.morzh — 10:37 AM
÷1 to Sincere Richard. I use Mouser but either is the way to go. I'm sure the others, like justradios, are in the group...RodB — 10:24 AM
RS3, that output transistor X6…AR14, can be replaced with a GE-3 or ECG-121, probably others too. Ron462ron — 10:01 AM
Philco 7053
Thread moved to test equipment section. (I have not used one of these)klondike98 — 07:05 AM
Thank you Richard.R3Sons — 01:37 AM
R3Sons, I buy my resistors from either digi key or mouser ! Sincerely Richardradiorich — 01:28 AM
Replicating (dogbone) resistors what method have you used ?
Hello Guys, I can't wait to try printing some of these I might go ahead and order some from PCB way ! Sincerely Richardradiorich — 01:26 AM
