Guitar Amp
I pronounce it fixed. I replaced the rest of the e caps, put back together and found some of the cracking static came back until it warmed up. I pulled both boards and resoldered a bunch of suspicious looking connections. I put back together kinda loose to be able to flex things and pull again and had no sound at all! Huh ... so after some messing around I found flexing the board made the sound (and static) come and go and could see the output tubes flash inside (not sparking, you know -the look inside when the tubes are handling current). Well, I discovered the outputs were grounded through the screws and stand-offs that hold the octal tube sockets to the metal chassis! So, I went back and cleaned and tightened those screws very tight - quiet as a church mouse! So, if anyone has one of these amps with static/cracking noises and cleaning controls and replacing tubes doesnt completely quiet it, clean those studs or solder a ground to those to chassis ground. I still have a very light, low level hum, but I think it is the nature of the beast for the most part. It's not really HiFi, so it may not be completely quiet like a Fisher or Dyna.
Tim
Guitar Amp - by TV MAN - 10-03-2019, 01:07 PM
RE: Guitar Amp - by morzh - 10-03-2019, 01:15 PM
RE: Guitar Amp - by TV MAN - 10-03-2019, 01:30 PM
RE: Guitar Amp - by mikethedruid - 10-03-2019, 01:41 PM
RE: Guitar Amp - by Eliot Ness - 10-03-2019, 02:31 PM
RE: Guitar Amp - by Ron Ramirez - 10-03-2019, 03:25 PM
RE: Guitar Amp - by TV MAN - 10-03-2019, 10:37 PM
RE: Guitar Amp - by Ron Ramirez - 10-03-2019, 10:39 PM
RE: Guitar Amp - by morzh - 10-04-2019, 09:48 AM
RE: Guitar Amp - by TV MAN - 11-23-2019, 12:36 PM
RE: Guitar Amp - by morzh - 11-24-2019, 04:09 PM
RE: Guitar Amp - by TV MAN - 11-28-2019, 12:05 PM
RE: Guitar Amp - by TV MAN - 12-15-2019, 08:07 PM
RE: Guitar Amp - by Ron Ramirez - 12-15-2019, 11:14 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 6491 online users. [Complete List]
» 2 Member(s) | 6489 Guest(s)
