Ron's RCA 9T/10K
OK Russ, thanks. Of course I don't have any suitable shielded wire. So I have ordered some, after checking that 22 gauge wire would safely handle the current of three tubes plus four LED dial lamps (it will). The wire I ordered, from Mouser, has PTFE insulation so it is more resistant to soldering iron heat. While I was at it, I also ordered enough mica capacitors to replace all 473 micas in the Magic Brain.
(No, it doesn't use quite that many mica caps...but it seems like it)
I suppose as long as I am doing this right, I should perform the 6SG7 mod as well? This mod replaces the 6K7 RF amp tube with a 6SG7. The 6SG7 will ensure that band "D" (23 to 60 mc) will work across the entire band, not just the low end as with most 6K7 tubes. It requires a new octal socket with all eight pins - the 6K7 socket is missing the contact for pin 6.
But then again, what can be received between 23 and 60 mc utilizing amplitude modulation these days? Hmmm. Upon second thought, it seems like a lot of work for little or no return. I don't think I will do that.
I'm not going to work on the Magic Brain tonight. Maybe I will tomorrow night.
Ron's RCA 9T/10K - by Ron Ramirez - 12-10-2019, 10:03 PM
RE: Ron's RCA 9T/10K - by mikethedruid - 12-10-2019, 10:16 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-10-2019, 10:18 PM
RE: Ron's RCA 9T/10K - by Nathan Slingerland - 12-11-2019, 12:12 AM
RE: Ron's RCA 9T/10K - by mikethedruid - 12-11-2019, 02:35 AM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-11-2019, 07:16 AM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-11-2019, 07:18 AM
RE: Ron's RCA 9T/10K - by Eliot Ness - 12-11-2019, 10:30 AM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-13-2019, 10:05 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-13-2019, 10:19 PM
RE: Ron's RCA 9T/10K - by Steve Davis - 12-13-2019, 10:39 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-14-2019, 11:47 PM
RE: Ron's RCA 9T/10K - by jake wells - 12-15-2019, 05:59 AM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-15-2019, 10:39 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-15-2019, 10:47 PM
RE: Ron's RCA 9T/10K - by jake wells - 12-15-2019, 10:53 PM
RE: Ron's RCA 9T/10K - by Phlogiston - 12-16-2019, 01:44 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-16-2019, 07:48 PM
RE: Ron's RCA 9T/10K - by Phlogiston - 12-16-2019, 07:59 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-16-2019, 11:32 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-19-2019, 11:06 PM
RE: Ron's RCA 9T/10K - by rfeenstra - 12-19-2019, 11:51 PM
RE: Ron's RCA 9T/10K - by EdHolland - 12-20-2019, 01:30 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-20-2019, 11:38 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-21-2019, 02:03 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-21-2019, 11:26 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-21-2019, 11:28 PM
RE: Ron's RCA 9T/10K - by KCMike - 12-22-2019, 05:58 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-22-2019, 07:32 PM
RE: Ron's RCA 9T/10K - by EdHolland - 12-23-2019, 06:14 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-23-2019, 10:34 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-23-2019, 10:40 PM
RE: Ron's RCA 9T/10K - by Nathan Slingerland - 12-23-2019, 10:41 PM
RE: Ron's RCA 9T/10K - by Steve Davis - 12-23-2019, 11:24 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-24-2019, 08:29 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-25-2019, 10:22 PM
RE: Ron's RCA 9T/10K - by Paul Philco322 - 12-25-2019, 10:44 PM
RE: Ron's RCA 9T/10K - by 462ron - 12-26-2019, 11:49 AM
RE: Ron's RCA 9T/10K - by EdHolland - 12-26-2019, 01:11 PM
Thank you Richard.R3Sons — 01:37 AM
R3Sons, I buy my resistors from either digi key or mouser ! Sincerely Richardradiorich — 01:28 AM
Replicating (dogbone) resistors what method have you used ?
Hello Guys, Ican't wait to try printing some of these I might go ahead and order some from PCB way ! Sincerely Richa...radiorich — 01:26 AM
Does anybody have a line on replacement resistors?R3Sons — 12:21 AM
42-345 Resistors
I replaced all the electrolytic capacitors. That big Philco 12uf 400V electrolytic Vienna sausage. is one I removed and ...proftrussell — 11:58 PM
Well...taht's a start.morzh — 10:15 PM
X6 is out. Only pulling 3mA now, 220mA with the light on. Test point 18 is 12.2 Test point 19 is 12.06R3Sons — 09:46 PM
Philco 7053
Any of you guys have and used this tester?Martinj — 09:27 PM
I would test all, but the X6 is the main suspect. The output is the autotransformer, and it also could potentially ha...morzh — 09:13 PM
Yes, I tested them out of the circuits. I posted my measurements where the first letter was red and the second was blac...R3Sons — 08:52 PM
