1936 Philco 116B Tombstone Radio - Cabinet Questions
Actually I'm doing the electrical restore first then the cabinet, I was just trying to get some opinions on what would be good to use on the cabinet to refinish it when I get to that stage of the project (which won't be happening until spring as I don't have access to a heated, ventilated garage.)
RE: Just picked up a 1936 Philco 116B Tombstone Radio Today and need some info on it - by captainclock1988 - 12-17-2019, 09:42 PM
