Source for non-spray-can toner?
Try this. I'm planning on purchasing some of their dyes soon because I too have the spray equipment and it would be cheaper in the long run than rattle cans.
http://www.veneersupplies.com/categories...6__Stains/
Jay
Source for non-spray-can toner? - by audin - 01-14-2011, 06:39 PM
Re: Source for non-spray-can toner? - by Jayg30 - 01-14-2011, 08:02 PM
Re: Source for non-spray-can toner? - by exray - 01-15-2011, 11:20 PM
Re: Source for non-spray-can toner? - by audin - 01-16-2011, 12:05 AM
There are currently 10534 online users. [Complete List]
» 3 Member(s) | 10531 Guest(s)
