Control extension shafts.
Radio Daze sells shaft couplers. With one of these and a piece of .25 in. aluminum rod you can make any length.
Control extension shafts. - by Stall-U-Rated - 12-19-2019, 02:46 AM
RE: Control extension shafts. - by radiodale - 12-19-2019, 10:20 AM
RE: Control extension shafts. - by Phlogiston - 12-19-2019, 12:44 PM
RE: Control extension shafts. - by Stall-U-Rated - 12-21-2019, 12:16 AM
RE: Control extension shafts. - by mikethedruid - 12-21-2019, 12:26 AM
RE: Control extension shafts. - by Stall-U-Rated - 12-22-2019, 05:21 PM
RE: Control extension shafts. - by mikethedruid - 12-22-2019, 05:27 PM
RE: Control extension shafts. - by radiodale - 12-23-2019, 11:46 PM
There are currently 4355 online users. [Complete List]
» 1 Member(s) | 4354 Guest(s)
