Ron's RCA 9T/10K
Thanks Ed.
Progress:
There are a few mica capacitors which are soldered to the trimmer capacitors, such as this:
I decided not to replace these, since those metal rings you see around the trimmers are made of solder, and I didn't want to mess them up.
Topside progress:
Still to do: One more mica cap underneath, one more mica cap and one more resistor on the top, plus one more grid cap lead to replace on top. Also polish and reinstall the shields for the open coils you see above. And them make and install a replacement wiring harness and the Magic Brain should then be complete.
If all goes well, I hope to have the Magic Brain back in the main chassis sometime tomorrow - and also hope to apply power to it for the first time tomorrow as well.
Ron's RCA 9T/10K - by Ron Ramirez - 12-10-2019, 10:03 PM
RE: Ron's RCA 9T/10K - by mikethedruid - 12-10-2019, 10:16 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-10-2019, 10:18 PM
RE: Ron's RCA 9T/10K - by Nathan Slingerland - 12-11-2019, 12:12 AM
RE: Ron's RCA 9T/10K - by mikethedruid - 12-11-2019, 02:35 AM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-11-2019, 07:16 AM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-11-2019, 07:18 AM
RE: Ron's RCA 9T/10K - by Eliot Ness - 12-11-2019, 10:30 AM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-13-2019, 10:05 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-13-2019, 10:19 PM
RE: Ron's RCA 9T/10K - by Steve Davis - 12-13-2019, 10:39 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-14-2019, 11:47 PM
RE: Ron's RCA 9T/10K - by jake wells - 12-15-2019, 05:59 AM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-15-2019, 10:39 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-15-2019, 10:47 PM
RE: Ron's RCA 9T/10K - by jake wells - 12-15-2019, 10:53 PM
RE: Ron's RCA 9T/10K - by Phlogiston - 12-16-2019, 01:44 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-16-2019, 07:48 PM
RE: Ron's RCA 9T/10K - by Phlogiston - 12-16-2019, 07:59 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-16-2019, 11:32 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-19-2019, 11:06 PM
RE: Ron's RCA 9T/10K - by rfeenstra - 12-19-2019, 11:51 PM
RE: Ron's RCA 9T/10K - by EdHolland - 12-20-2019, 01:30 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-20-2019, 11:38 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-21-2019, 02:03 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-21-2019, 11:26 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-21-2019, 11:28 PM
RE: Ron's RCA 9T/10K - by KCMike - 12-22-2019, 05:58 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-22-2019, 07:32 PM
RE: Ron's RCA 9T/10K - by EdHolland - 12-23-2019, 06:14 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-23-2019, 10:34 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-23-2019, 10:40 PM
RE: Ron's RCA 9T/10K - by Nathan Slingerland - 12-23-2019, 10:41 PM
RE: Ron's RCA 9T/10K - by Steve Davis - 12-23-2019, 11:24 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-24-2019, 08:29 PM
RE: Ron's RCA 9T/10K - by Ron Ramirez - 12-25-2019, 10:22 PM
RE: Ron's RCA 9T/10K - by Paul Philco322 - 12-25-2019, 10:44 PM
RE: Ron's RCA 9T/10K - by 462ron - 12-26-2019, 11:49 AM
RE: Ron's RCA 9T/10K - by EdHolland - 12-26-2019, 01:11 PM
Users browsing this thread: 14 Guest(s)
Thank you Richard.R3Sons — 01:37 AM
R3Sons, I buy my resistors from either digi key or mouser ! Sincerely Richardradiorich — 01:28 AM
Replicating (dogbone) resistors what method have you used ?
Hello Guys, Ican't wait to try printing some of these I might go ahead and order some from PCB way ! Sincerely Richa...radiorich — 01:26 AM
Does anybody have a line on replacement resistors?R3Sons — 12:21 AM
42-345 Resistors
I replaced all the electrolytic capacitors. That big Philco 12uf 400V electrolytic Vienna sausage. is one I removed and ...proftrussell — 11:58 PM
Well...taht's a start.morzh — 10:15 PM
X6 is out. Only pulling 3mA now, 220mA with the light on. Test point 18 is 12.2 Test point 19 is 12.06R3Sons — 09:46 PM
Philco 7053
Any of you guys have and used this tester?Martinj — 09:27 PM
I would test all, but the X6 is the main suspect. The output is the autotransformer, and it also could potentially ha...morzh — 09:13 PM
Yes, I tested them out of the circuits. I posted my measurements where the first letter was red and the second was blac...R3Sons — 08:52 PM
