37-650 Saga continues...
Thanks, Chuck- I'll start the "laundry list" with the tube swaps, and go from there...
Thanks again,
Scott
Old Cars, Old Radios, Old Pipes and Young Women... What more is there?
37-650 Saga continues... - by Robbie Roberts - 02-27-2006, 06:55 PM
[No subject] - by Chuck Schwark - 02-27-2006, 07:22 PM
I'm still fighting... - by Robbie Roberts - 02-28-2006, 06:26 PM
[No subject] - by Steve Chambers - 02-28-2006, 08:21 PM
[No subject] - by Chuck Schwark - 02-28-2006, 08:38 PM
[No subject] - by Robbie Roberts - 02-28-2006, 09:22 PM
[No subject] - by Robbie Roberts - 02-28-2006, 10:21 PM
[No subject] - by Chuck Schwark - 02-28-2006, 10:46 PM
[No subject] - by Robbie Roberts - 02-28-2006, 11:31 PM
Philco 91 Tuning Condenser
