Frankenphilco?
Got the seller to send me a pic of the back.
[Image: https://i.imgur.com/T78Djfx.jpg]
Frankenphilco? - by Patrick - 12-28-2019, 10:22 PM
RE: Frankenphilco? - by Radioroslyn - 12-28-2019, 11:37 PM
RE: Frankenphilco? - by Patrick - 12-29-2019, 06:24 AM
RE: Frankenphilco? - by Radioroslyn - 12-29-2019, 10:52 AM
RE: Frankenphilco? - by Patrick - 12-29-2019, 12:02 PM
Philco 91 Tuning Condenser
