How to remove power switch 41-608
I put a new switch in today. I used the one from lowes but didn't disassemble the new one. Instead I filed some of the tip off of the stem (about 3/16 of an inch), used epoxy to glue the feral to the old switch location and screwed the switch in until it functioned correctly. Locked in place with the lock nut that came with the switch and now it works perfectly.
How to remove power switch 41-608 - by Derek38 - 12-27-2019, 03:08 PM
RE: How to remove power switch 41-608 - by Derek38 - 12-29-2019, 08:15 PM
There are currently 4480 online users. [Complete List]
» 1 Member(s) | 4479 Guest(s)
