Mystery
"Octals?"
Yes.... the larger glass tubes with the larger bases and up to 8 pins. Neither schematic that David just sent can be it...the one has 7-pin miniature tubes....the other has SIX octals...yours only has 5.   Icon_wtf
Mystery - by mrmurr2003 - 12-26-2019, 10:24 PM
RE: Mystery - by Ron Ramirez - 12-26-2019, 10:31 PM
RE: Mystery - by Radioroslyn - 12-26-2019, 11:21 PM
RE: Mystery - by mrmurr2003 - 12-27-2019, 04:03 PM
RE: Mystery - by Radioroslyn - 12-27-2019, 05:43 PM
RE: Mystery - by mrmurr2003 - 12-27-2019, 06:37 PM
RE: Mystery - by OldRestorer - 12-28-2019, 04:37 PM
RE: Mystery - by mrmurr2003 - 12-28-2019, 04:49 PM
RE: Mystery - by mikethedruid - 12-28-2019, 06:43 PM
RE: Mystery - by batterymaker - 12-28-2019, 11:51 PM
RE: Mystery - by David - 12-29-2019, 02:37 PM
RE: Mystery - by Jake Blake - 12-29-2019, 03:55 PM
RE: Mystery - by mrmurr2003 - 12-30-2019, 06:41 PM
RE: Mystery - by mrmurr2003 - 12-30-2019, 06:54 PM
RE: Mystery - by David - 12-30-2019, 07:54 PM
RE: Mystery - by Jake Blake - 12-30-2019, 08:29 PM
RE: Mystery - by Jake Blake - 12-30-2019, 08:35 PM
RE: Mystery - by David - 12-30-2019, 10:15 PM
RE: Mystery - by Jake Blake - 12-30-2019, 10:23 PM
X6 is out. Only pulling 3mA now, 220mA with the light on. Test point 18 is 12.2 Test point 19 is 12.06R3Sons — 09:46 PM
Philco 7053
Any of you guys have and used this tester?Martinj — 09:27 PM
I would test all, but the X6 is the main suspect. The output is the autotransformer, and it also could potentially ha...morzh — 09:13 PM
Yes, I tested them out of the circuits. I posted my measurements where the first letter was red and the second was blac...R3Sons — 08:52 PM
1. Have you tested out of circuit? 2. If yes, any transistor not showing E-C as OL is bad. From your measurements, all...morzh — 08:27 PM
42-345 Resistors
In short (I a sure you've seen the video Rich provided), safety caps are X and Y. X caps are placed across the Line/Neu...morzh — 08:21 PM
Restoring Philco 96
Today I decided to take on gutting the big bad cap block. I gave up on the same one from the 86 before, so I was not sur...morzh — 08:13 PM
42-345 Resistors
To not replace is to put it on the list to do later when they cook up! As a radio guy would say back in the day, lets sp...Paul Philco322 — 07:19 PM
Here's the readings from the AR14 (No markings on the one from the 5TPO) on the 6TPZ: B-E OL E-B .14 B-C 2.9 C-B .13...R3Sons — 04:17 PM
Thank you all so much. First the power supply: "KORAD KA3005P - Programmable Precision Variable Adjustable 30V, 5A...R3Sons — 03:48 PM
There are currently 2616 online users. [Complete List]
» 2 Member(s) | 2614 Guest(s)
