connecting eico 324 audio or rf connectors
Have you tested the generator to see if work? Set the band switch to the band that cover the broadcast band. Set modulation for internal (this will give you a 400cy tone) Set rf output for max. Set the frequency on the generator to 1400kc and tune a working receiver to the same.Connect the generator output(cable on the right)to the antenna post of the receiver. If it is working you will hear a 400cy in your receiver.
If you want to eject a signal into the IF,though a small cap hook it to the plate of mixer tube. Be careful as there is HV at this point
You may want to deal with the hum problem first.
Re: connecting eico 324 audio or rf connectors - by 7estatdef - 01-16-2011, 10:33 PM
Philco 89 indicator light.
