Just picked up a 1936 Philco 116B Tombstone Radio Today and need some info on it
#45
To get the braid unsolder from the bolts this works well: https://www.ebay.com/itm/WELLER-Solderin...SwDoNeBPYp It's mis listed here as it's one of the older 325w units and is better than the newer 260 watt. Might need a tip. [Image: https://philcoradio.com/phorum/images/sm...n_cool.gif]
Most of the time the rubber grommets under the tuning cap are shot making the cap wobble and cause the tuning shaft to rub on the cabinet. The fix is to unsolder the braid, remove the 1/4"hex screws and replace the grommets.
RE: Just picked up a 1936 Philco 116B Tombstone Radio Today and need some info on it - by Radioroslyn - 01-03-2020, 09:46 AM
There are currently 3457 online users. [Complete List]
» 1 Member(s) | 3456 Guest(s)
