Olympic 6-608-110
Actually, Jake, it is because of the orientation of the pulsing magnetic field on the wires. They run horizontally, and the antenna is vertical. its reception field is at 90 degrees to that which the lines create. It was inspired by an old drawing I saw in one of my books which advised orienting a long wire antenna at 90 degrees to any trolley lines which ran in front of your house. I considered the best way to accomplish thins in the least space, and decided on a vertically oriented antenna. It has the added advantage over a long wire in that it is omni-directional, and receives equally well from all directions. It is really an ideal antenna for my use; it works well for all directions, and takes very little space, just clearance above it, and it minimizes the interference from the power lines. Much more practical for my use than a long wire. Everybody's Radio Manual, page 141...
[Image: https://66.media.tumblr.com/3f86a67662ef...b7096a.jpg]
This is a very useful old book, and has a whole section on how to eliminate interference from your receiver.
Olympic 6-608-110 - by mikethedruid - 10-17-2019, 12:11 AM
RE: Olympic 6-608-110 - by mikethedruid - 10-18-2019, 10:56 PM
RE: Olympic 6-608-110 - by Paul Philco322 - 10-19-2019, 08:22 AM
RE: Olympic 6-608-110 - by mikethedruid - 10-19-2019, 12:08 PM
RE: Olympic 6-608-110 - by Ron Ramirez - 10-19-2019, 03:21 PM
RE: Olympic 6-608-110 - by Jake Blake - 12-11-2019, 02:44 PM
RE: Olympic 6-608-110 - by mikethedruid - 12-11-2019, 07:30 PM
RE: Olympic 6-608-110 - by Jake Blake - 12-11-2019, 08:09 PM
RE: Olympic 6-608-110 - by mikethedruid - 12-14-2019, 06:21 PM
RE: Olympic 6-608-110 - by Jake Blake - 12-14-2019, 06:27 PM
RE: Olympic 6-608-110 - by mikethedruid - 12-14-2019, 06:32 PM
RE: Olympic 6-608-110 - by Paul Philco322 - 12-14-2019, 07:27 PM
RE: Olympic 6-608-110 - by mikethedruid - 12-14-2019, 07:41 PM
RE: Olympic 6-608-110 - by jake wells - 12-15-2019, 05:54 AM
RE: Olympic 6-608-110 - by mikethedruid - 12-22-2019, 12:25 AM
RE: Olympic 6-608-110 - by mikethedruid - 12-26-2019, 05:29 PM
RE: Olympic 6-608-110 - by Jake Blake - 12-26-2019, 05:34 PM
RE: Olympic 6-608-110 - by mikethedruid - 12-26-2019, 06:58 PM
RE: Olympic 6-608-110 - by Jake Blake - 12-26-2019, 08:04 PM
RE: Olympic 6-608-110 - by mikethedruid - 12-31-2019, 06:25 PM
RE: Olympic 6-608-110 - by NostalgiaRadioTime - 12-31-2019, 10:19 PM
RE: Olympic 6-608-110 - by mikethedruid - 12-31-2019, 10:34 PM
RE: Olympic 6-608-110 - by Ron Ramirez - 01-01-2020, 09:26 AM
RE: Olympic 6-608-110 - by mikethedruid - 01-04-2020, 10:41 AM
RE: Olympic 6-608-110 - by Jake Blake - 01-04-2020, 10:58 AM
RE: Olympic 6-608-110 - by mikethedruid - 01-04-2020, 12:24 PM
RE: Olympic 6-608-110 - by Jake Blake - 01-04-2020, 12:40 PM
RE: Olympic 6-608-110 - by mikethedruid - 01-04-2020, 04:13 PM
RE: Olympic 6-608-110 - by Jake Blake - 01-04-2020, 08:10 PM
RE: Olympic 6-608-110 - by Paul Philco322 - 01-04-2020, 09:37 PM
42-345 Resistors
Mike, Thank you for the reply and for correcting the year on my subject. Little and Big Phil are indeed 42s. The b...proftrussell — 12:13 AM
32-345 Resistors
You seem to have gotten the values right. Yes the damage is consistent with a wrong polarity of the first rectifier filt...morzh — 11:47 PM
42-345 Resistors
Phorum Phriends, I have some questions about resistors in my 42-345.  Before getting to the confessional aspect of...proftrussell — 11:28 PM
Canadian GE Model 41
Umm....you do not clean potentiometers with contact cleaner. Unless cleaning the carbon layer of the base is the goal. Y...morzh — 05:52 PM
I got the tube tested and it was TU. I have installed a replacement tube. During this last effort I discovered part of...Mtmattking — 04:01 PM
Restoring Philco 96
I opened up and lubed the volume pot. It is suposed to be 500K (no one expects it to be that), and it is about 1.5M. T...morzh — 03:34 PM
Compatible crts
The 5JP1 sounds like either like a military tube, or one built for some piece of older industrial equipment.Arran — 02:59 PM
Thank you morzh. I will try that today.R3Sons — 02:06 PM
A man who repairs tube radios is capable of many things. Capable of anything :lol: Beware.morzh — 01:40 PM
Philco 91 Tuning Condenser
Yes, in those it is. In 20/90 it is a metal spring that holds the rotor in the cradles of the outer walls.morzh — 01:39 PM
There are currently 2089 online users. [Complete List]
» 2 Member(s) | 2087 Guest(s)
