BAKELITE BLOCK TYPE capacitors
Swiped a pair out of a DVR to use in a radio im restoring. This radio had only one as pictured in the corner. So, i unsoldered the center conductor from it and tucked it to the side and installed these 2 little fellas... Icon_biggrin
BAKELITE BLOCK TYPE capacitors - by fenbach - 12-31-2019, 08:51 PM
RE: BAKELITE BLOCK TYPE capacitors - by radiodale - 12-31-2019, 10:43 PM
RE: BAKELITE BLOCK TYPE capacitors - by morzh - 01-01-2020, 02:27 PM
RE: BAKELITE BLOCK TYPE capacitors - by Kestas - 01-01-2020, 09:29 PM
RE: BAKELITE BLOCK TYPE capacitors - by morzh - 01-02-2020, 10:58 AM
RE: BAKELITE BLOCK TYPE capacitors - by fenbach - 01-04-2020, 02:11 PM
RE: BAKELITE BLOCK TYPE capacitors - by morzh - 01-04-2020, 08:59 PM
RE: BAKELITE BLOCK TYPE capacitors - by Stall-U-Rated - 01-04-2020, 09:20 PM
There are currently 3892 online users. [Complete List]
» 1 Member(s) | 3891 Guest(s)
