Aluminum Filter Capacitors
A couple of weeks ago, I bought a box of aluminum electrolytic capacitors from a fellow on "ARF". They were all twist lock and PC mount. I have a few Philco chassis that were missing the filter caps, one I had robbed for the 90 I just restored and a couple that were missing them already. The plan is to gut the cans, re-stuff and modify the mount to the large threaded stud. Yeah, I know aluminum cans are not original on the early Philcos but I figure aluminum cans look better than empty holes.
 [Image: https://live.staticflickr.com/65535/4934...54c3_k.jpg]100_0294 by Steve Davis, on Flickr
I went to the Habitat For Humanity Restore looking for PVC pipe fittings and found these schedule 80 unions for 50 cents each.
[Image: https://live.staticflickr.com/65535/4934...f2c0_k.jpg]100_0290 by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/4934...0438_k.jpg]100_0291 by Steve Davis, on Flickr
I cut the flange of the union down in the lathe to fit inside the aluminum can.
[Image: https://live.staticflickr.com/65535/4934...1e1b_k.jpg]100_0281 by Steve Davis, on Flickr
A PVC "close" nipple was screwed into the flange. First the threads had to be re-tapped because the nipple is now screwed in from the opposite side than the hole was originally tapped.
 [Image: https://live.staticflickr.com/65535/4934...24c2_k.jpg]100_0283 by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/4934...2167_k.jpg]100_0286 by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/4934...081c_k.jpg]100_0287 by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/4934...2a47_k.jpg]100_0298 by Steve Davis, on Flickr
I have not stuffed the cans yet, will do that as I need them, will probably use film caps.
M R Radios   C M Tubes
Aluminum Filter Capacitors - by Steve Davis - 01-07-2020, 10:06 PM
RE: Aluminum Filter Capacitors - by Stall-U-Rated - 01-08-2020, 12:21 AM
RE: Aluminum Filter Capacitors - by rfeenstra - 01-08-2020, 12:28 AM
RE: Aluminum Filter Capacitors - by EdHolland - 01-08-2020, 01:10 PM
RE: Aluminum Filter Capacitors - by David - 01-08-2020, 09:12 PM
There are currently 2938 online users. [Complete List]
» 5 Member(s) | 2933 Guest(s)
AvatarAvatarAvatarAvatar
