Help with a model...
Looks like a 1941 Model 41-295X or 41-296X. Model number should be on a paper sticker on the inside of the cabinet.
Help with a model... - by Guest - 03-01-2006, 05:45 PM
[No subject] - by Chuck Schwark - 03-01-2006, 07:36 PM
[No subject] - by 49Stude63 - 03-01-2006, 09:56 PM
[No subject] - by Chuck Schwark - 03-01-2006, 10:46 PM
[No subject] - by 49Stude63 - 03-02-2006, 03:38 PM
[No subject] - by Guest - 03-24-2006, 05:01 PM
[No subject] - by PTurney - 03-24-2006, 06:53 PM
[No subject] - by Guest - 04-11-2006, 03:08 PM
[No subject] - by Chuck Schwark - 04-11-2006, 07:01 PM
Philco 91 Tuning Condenser
There are currently 10060 online users. [Complete List]
» 1 Member(s) | 10059 Guest(s)
