A silent 1928 Philco 511
Hi Bud and Welcome,
Give this a try https://philcoradio.com/library/index.ph...chematics/ Click on 511. If #70 is missing you should be able apply an audio signal to #24 and hear the signal thru the speaker if all is well. 70 provides the hv to the 27 tube which is the detector. That's why for now the set isn't receiving, there maybe other issues. Would go through and check all of the pin 2's of the 26's to see if you have hv there. In good working order about 135v of lower the bypass cap connected to it is leaky. If 0 the coil is open and will require a rewind.
A silent 1928 Philco 511 - by Bud - 01-10-2020, 05:49 PM
RE: A silent 1928 Philco 511 - by klondike98 - 01-10-2020, 06:00 PM
RE: A silent 1928 Philco 511 - by Radioroslyn - 01-10-2020, 06:12 PM
RE: A silent 1928 Philco 511 - by Bud - 01-13-2020, 11:23 AM
RE: A silent 1928 Philco 511 - by Daddyo1949 - 01-13-2020, 07:48 PM
RE: A silent 1928 Philco 511 - by Radioroslyn - 01-13-2020, 08:58 PM
Canadian GE Model 41
Umm....you do not clean potentiometers with contact cleaner. Unless cleaning the carbon layer of the base is the goal. Y...morzh — 05:52 PM
I got the tube tested and it was TU. I have installed a replacement tube. During this last effort I discovered part of...Mtmattking — 04:01 PM
Restoring Philco 96
I opened up and lubed the volume pot. It is suposed to be 500K (no one expects it to be that), and it is about 1.5M. T...morzh — 03:34 PM
Compatible crts
The 5JP1 sounds like either like a military tube, or one built for some piece of older industrial equipment.Arran — 02:59 PM
Thank you morzh. I will try that today.R3Sons — 02:06 PM
A man who repairs tube radios is capable of many things. Capable of anything :lol: Beware.morzh — 01:40 PM
Philco 91 Tuning Condenser
Yes, in those it is. In 20/90 it is a metal spring that holds the rotor in the cradles of the outer walls.morzh — 01:39 PM
