Philco 41-250
I apologize for not adding this to my last reply... I would also like to know if anyone would have the correct chassis to case spacers and screws/washers? As you can see in the pics, the chassis is more or less centered with pieces of cardboard...Also, does anyone repro the brass strip across the escucheon?
thanks again!
Andy
Philco 41-250 - by andyjon100 - 01-21-2011, 05:56 PM
RE: Philco 41-250 - by GACTVDX - 09-17-2014, 08:57 PM
Re: Philco 41-250 - by Ron Ramirez - 01-21-2011, 07:25 PM
Re: Philco 41-250 - by andyjon100 - 01-21-2011, 10:45 PM
Re: Philco 41-250 - by andyjon100 - 01-21-2011, 10:50 PM
Re: Philco 41-250 - by gary rabbitt - 01-22-2011, 03:13 AM
Re: Philco 41-250 - by Ron Ramirez - 01-22-2011, 08:57 AM
Re: Philco 41-250 - by Ron Ramirez - 01-22-2011, 09:15 AM
Re: Philco 41-250 - by andyjon100 - 01-22-2011, 01:09 PM
Re: Philco 41-250 - by gary rabbitt - 01-22-2011, 01:48 PM
Re: Philco 41-250 - by Ron Ramirez - 01-22-2011, 02:55 PM
Re: Philco 41-250 - by andyjon100 - 01-22-2011, 03:19 PM
Re: Philco 41-250 - by Art Hoch - 02-04-2011, 01:09 PM
Re: Philco 41-250 - by andyjon100 - 02-05-2011, 02:00 AM
There are currently 9553 online users. [Complete List]
» 3 Member(s) | 9550 Guest(s)
