Philco 7050 tube tester
I have made the four buttons out of epoxy resin and painted them the same blue.
 Now I need to find the silver PHILCO in a transfer or letter stickers and
a few coats of clear gloss lacquer. Dose anyone have
ideas on the lettering?
Philco 7050 tube tester - by truePhilco - 01-11-2020, 06:26 PM
RE: Philco 7051 tube tester - by klondike98 - 01-11-2020, 08:24 PM
RE: Philco 7050 tube tester - by truePhilco - 01-25-2020, 09:56 PM
RE: Philco 7050 tube tester - by klondike98 - 01-26-2020, 01:43 PM
Eico 232 VTVM Schematic
There are currently 9013 online users. [Complete List]
» 2 Member(s) | 9011 Guest(s)
