Philco 41-250
Two more pictures of my 41-250.
[Image: http://www.philcoradio.com/images/phorum/ARF/41250a.jpg]
See where the PHILCO decal is above the dial? I've never seen this decal in any other location on these sets.
I need to clean this set up, and get rid of the last bits of packing (shredded paper) still in the speaker grille.
[Image: http://www.philcoradio.com/images/phorum/ARF/41250b.jpg]
Here, you can see the new reproduction escutcheon, still in the bag it came in. I should have pulled it out of the bag and photographed it. Maybe I'll do that later if I don't forget about it.
Edit: Yes, Andy, the correct decal can be purchased from Antique Electronic Supply (part number S-M907). The sheet you get includes the PHILCO name in three sizes; you want to use the largest one. You'll also find a link to them on the Resources page - see link above in Gary's post.
Don't use those awful decals from Radio Daze (the DCL-PH9) if you care about how your radio looks. They look nothing like the originals.
Philco 41-250 - by andyjon100 - 01-21-2011, 05:56 PM
RE: Philco 41-250 - by GACTVDX - 09-17-2014, 08:57 PM
Re: Philco 41-250 - by Ron Ramirez - 01-21-2011, 07:25 PM
Re: Philco 41-250 - by andyjon100 - 01-21-2011, 10:45 PM
Re: Philco 41-250 - by andyjon100 - 01-21-2011, 10:50 PM
Re: Philco 41-250 - by gary rabbitt - 01-22-2011, 03:13 AM
Re: Philco 41-250 - by Ron Ramirez - 01-22-2011, 08:57 AM
Re: Philco 41-250 - by Ron Ramirez - 01-22-2011, 09:15 AM
Re: Philco 41-250 - by andyjon100 - 01-22-2011, 01:09 PM
Re: Philco 41-250 - by gary rabbitt - 01-22-2011, 01:48 PM
Re: Philco 41-250 - by Ron Ramirez - 01-22-2011, 02:55 PM
Re: Philco 41-250 - by andyjon100 - 01-22-2011, 03:19 PM
Re: Philco 41-250 - by Art Hoch - 02-04-2011, 01:09 PM
Re: Philco 41-250 - by andyjon100 - 02-05-2011, 02:00 AM
There are currently 4676 online users. [Complete List]
» 1 Member(s) | 4675 Guest(s)
