I may have goofed...
Thanks, Chuck! Think anything else down the line might have been damaged that I should look for? I was planning to replace the resistors and the two mica caps in the RF subchassis(which have already been replaced once) but if the 6,13, and 15 caps are the issue, I might not- unless you think there may be good reason to...
Thanks!
Scott
Old Cars, Old Radios, Old Pipes and Young Women... What more is there?
I may have goofed... - by Robbie Roberts - 03-02-2006, 01:48 AM
[No subject] - by Chuck Schwark - 03-02-2006, 10:00 AM
[No subject] - by Robbie Roberts - 03-02-2006, 10:33 AM
[No subject] - by Chuck Schwark - 03-02-2006, 10:44 AM
[No subject] - by Robbie Roberts - 03-02-2006, 10:53 AM
[No subject] - by Chuck Schwark - 03-02-2006, 11:37 AM
Philco 91 Tuning Condenser
There are currently 7258 online users. [Complete List]
» 2 Member(s) | 7256 Guest(s)
