37-620 dial lamp assembly
Patrrick, I have an extra dial lamp assembly on a 37-630 chassis I am stripping for parts. I need the electrolytics and clamps for the 37-640 I am restoring. It does not mount with a screw. The assembly has a spring metal clip that slides onto a metal tab. You'll have to clean it up, and spray the inside of the reflector with chrome paint, or re-plate it, and replace the center contact wire and rubber squishy inside. I used a tiny grommet from the auto parts store when I rebuilt the last one. I think Ron made a post about this a long time ago, you can see if you can find it. It is actually pretty easy and straightforward. I'm sure you can figure it out. PM me if you are interested. I'll be rebuilding the one for my 37-640 and will do photos showing how I do it. It uses the same part.
37-620 dial lamp assembly - by Patrick - 01-27-2020, 02:31 PM
RE: 37-620 dial lamp assembly - by radiodale - 01-27-2020, 03:43 PM
RE: 37-620 dial lamp assembly - by Patrick - 01-27-2020, 05:39 PM
RE: 37-620 dial lamp assembly - by mikethedruid - 01-27-2020, 10:38 PM
RE: 37-620 dial lamp assembly - by klondike98 - 01-28-2020, 12:50 PM
RE: 37-620 dial lamp assembly - by Patrick - 01-28-2020, 02:27 PM
There are currently 4386 online users. [Complete List]
» 2 Member(s) | 4384 Guest(s)
